Basket
Last modified by Андрей Калиновский on 2023/04/25 15:44
The Recycle Bin is the place where all deleted objects in the system go. There is no subscription fee for an item in the shopping cart. After deleting an object in the basket, all settings and its history are saved. However, no new data is written. An object in the trash can be stored for up to 365 days or until it is completely deleted by the user.
To display the Cart tab in the control panel, you must have the View Cart right . This right can be granted by the system role: Recycle Bin - View .
To go to the basket in the control panel, you need to find the tab Basket  and go to it. Inside is a table of remote objects and options to interact with it. There are two options: Clear  and Restore .
image-20221026104121-3.png  Clear  - the option allows you to permanently delete the selected objects.
 image-20221026114442-4.png  Restore  - the option allows you to restore the object to the client from which it was deleted.
To display the options Clear  and Restore  , you must have the rights, respectively, Restore from recycle bin and Empty recycle bin . These rights can be granted by the role: Recycle Bin - Restore. and cleaning .
In the table, by holding down the Shift or Ctrl key, you can select several objects and restore or clear them all at once.
GLONASSSoft wiki - 2023 г
