Geo object activity filter
Last modified by Андрей Калиновский on 2023/04/25 09:56
The activity filter allows you to quickly select geo objects in the visible part of the map or across the entire database based on their activity for the selected period.
The selection of geo-objects occurs depending on the duration of one or more objects on their territory. In this case, the minimum required time for finding objects can be set manually.
The activity filter allows you not to waste time studying the indicators of geo objects where no work has been done, which makes it a convenient tool for daily monitoring.
GLONASSSoft wiki - 2023 г
