Drivers
Last modified by Андрей Калиновский on 2023/04/25 14:47
The "Drivers" tab is designed to assign a driver to a selected vehicle in order to provide access control and time tracking.
The "Add driver" button  https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=bcf10f&media=create.png allows you to add a new driver from the directory to be assigned to the selected object. When choosing a driver, you can use the search.
After that, you need to assign a new driver to the object using the  https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=c94255&media=def.png "Set as default" button. Several drivers can be assigned to one object.
The button  https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=c3c290&media=delete.png removes the selected driver from the list.
Driver access control to the vehicle can be extended with an RFID reader and personal cards. This is especially important when performing critical work or when drivers work in shifts on the same vehicle.
GLONASSSoft wiki - 2023 г
