Tree of objects and geoobjects
Last modified by Андрей Калиновский on 2023/04/24 17:15
Tree of objects and geoobjects.
Trees of objects and geoobjects are two important similar and interconnected elements of the system, located in different sections "Monitoring" and "Geoobjects". They contain lists of all enterprise objects or geoobjects associated with it and are used for direct management of them, as well as for their display on the map and building reports on them.
The table rows of each tree are specific objects that have their own parameters and attributes.
Basic management of objects in the tree is performed using the toolbar, from which you can create, edit or delete objects/geoobjects, select objects by status and customize the view of the tabular part of the tree.
The tree toolbar contains a set of basic tools
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=bcf10f&media=create.png - create object/geobject
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=035d9c&media=edit.png - edit object/geobject
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=c3c290&media=delete.png - delete object/geobject
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=7520ba&media=update.png - update the data
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=a2d6c3&media=exp_imp.png - export/import of objects
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=a3f56d&media=taskmain.png - start of calculation of geo-events (only geo-object)
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=494143&media=state1.png https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=d3d068&media=state2.png https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=a0ce06&media=state3.png https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=3988d3&media=state4.png - filter objects by state (object only)
The tabular part of the trees provides finer tuning and tracking of the state of objects
All tables of object trees (geoobjects) contain the following elements:
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=6f4719&media=uncollapse.png - collapse/expand the list of objects
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=035d9c&media=edit.png - quick object editing
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=c3c290&media=delete.png - quick object removal
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=34858f&media=statusobject.png - object status - used to determine the activity of the object
The status of an object can be as follows:
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=0e30a2&media=moving_status.png - In motion  https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=403f33&media=on-line_status.png - Connected  https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=a7281e&media=parking_status.png - Parked  https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=c44f61&media=disconnect_status.png - Disconnected  https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=f66cf7&media=off-line_status.png - No data
The statuses "On the move", "No data", "Offline" are set by the system, the duration of transitions to the status "Online" and "Parking" can be configured manually.
Geoobjects have only two statuses "Active" and "Inactive"
The object tree contains additional elements:
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=a6d5ed&media=car.png - Object type
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=0d0444&media=follow.png - follow the object
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=343cab&media=engine.png - ignition
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=a6e0aa&media=stop.png - movement and stops
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=245dd3&media=speed.png - speed mode
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=17a7a5&media=drivers.png - assigned driver
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=80abef&media=calendar2.png - track for today
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=4db5bf&media=calendar3.png - track for yesterday
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=8b481c&media=calendar5.png - track for 24 hours
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=41d572&media=history.png - travel history
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=e393f6&media=state.png - object status
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=76be3c&media=notification.png - notifications
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=39359d&media=reports.png - build a waybill
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=2ed68a&media=code.png - send text command
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=a636ee&media=task_mehan.png - quick access menu
The tree of geo objects contains additional elements:
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=47e0e3&media=figure-polygon.png - type of geo object
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=a3f56d&media=taskmain.png - quick installation of geo-events calculation
GLONASSSoft wiki - 2023 г
