Visiting the fields
Last modified by Андрей Калиновский on 2023/04/25 11:29
The "Field visits" report displays information about the trips of equipment across the field in the specified time period. The report allows, without taking into account the fact, to perform a preliminary analysis of work in the field.
For the report to work, the object model must have the option Contains built-in aggregate . The report operation is also affected by the settings of the Geo objects filtering group . The object must spend within the field boundaries the period of time specified in the By time of location, sec setting , and if the By run of half of the geoobject perimeter option is enabled , then the run along the field is also taken into account, it must be greater than or equal to half of the field perimeter .
When building a report in the Fields panel , you can display trip tracks in the field when you select rows in the table.
The table displays the following information:
  • Button "Build history" - displayed when building a report through the monitoring system. Allows you to build a report directly from the table on the object specified in the "Object" column in this line. By default, the time and date the field was processed is specified.
  • Object - the name of the object that visited the field.
  • Field - the name of the visited field.
  • Year - the crop year that is specified for the field at the time it was visited.
  • Culture - the culture specified in the annual planning at the time of the visit to the field.
  • Area, ha - field area.
  • Start - the start time of the trip across the field.
  • End - the end time of the field trip.
  • Duration is the time spent driving around the field.
  • Engine hours - the total time of the object's engine operation during trips across the field.
  • Mileage, km - total mileage on a trip across the field.
  • Passed, ha - cultivated area of ​​the field during the trip. The data on the width of the unit are taken from the model of the object of the specified equipment.
  • Average speed, km/h - the average speed of the object in a trip across the field.
  • Max. speed, km/h - maximum speed in a trip across the field.
  • Fuel at start - fuel level at the beginning of the field trip.
  • Fuel at End - The fuel level at the end of a field trip.
  • Consumption, l / ha - the value of fuel consumption for the entire trip divided by the value of "Passed, ha".
GLONASSSoft wiki - 2023 г
