Module "Video monitoring"
Last modified by Андрей Калиновский on 2023/04/26 10:18
Video monitoring module
In the GLONASSSoft monitoring system, integration with the integrated CMSv6 platform was carried out.
We offer you to watch an overview video on this functionality:
The module allows you to broadcast live from the camera installation site, ensuring safety and control of the labor process. A real-time snapshot feature is also available, which automatically downloads a  https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=821dac&media=%D1%84%D0%BE000%D1%82%D0%BE.pngPNG image when clicked.
Access settings
If your user role has the "Video monitoring" right, you must configure it to use this feature. To do this, in the GLONASSSoft monitoring system, you need to select an object on the monitoring tab and click edit  https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=37bff9&media=%D1%80%D0%B5%D0%B4%D0%B0%D0%BA%D1%82%D0 %B8%D1%80%D0%BE%D0%B2%D0%B0%D1%82%D1%8C.png.
In the object card, go to other, click enable and fill in the settings fields of the object card.
Next, go to the tree  https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=b548c5&media=%D0%B4%D0%B5%D1%80%D0%B5%D0%B2%D0%BE.pngand turn on the display of the column with icons.
If you do not have access rights to the Video Monitoring module in the GLONASSSoft monitoring system, we recommend that you contact technical support.
For stable operation of the "Video monitoring" module, it is recommended to configure HTTPS support on the video server and specify it in the object card. Otherwise, the browser may block the connection to the video server without SSL. There will be a corresponding error in the console.
Add your video server address to the browser security check exception list.
GLONASSSoft wiki - 2023 г
