Issuing access rights
Last modified by Андрей Калиновский on 2023/04/26 11:05
The access rights distribution system makes it possible to create accounts for users with different capabilities and responsibilities, maintain hierarchical personnel structures of enterprises of any complexity.
User roles
A right  is a specific action that may or may not be available to the user, for example, viewing a directory of departments or adding a new monitoring object. The list of rights is fixed for the platform and cannot be edited by system users. The rights are grouped into groups, and if the group is active, then all the rights included in it are also active. User roles allow you to determine what rights to actions in the system will be available to users.
In addition to the list of rights, each role contains a list of roles available for assignment, for example, you can specify that users with the "Administrator" role can assign the "User" and "Technical support" roles to other users, Only these two roles will be available for assignment to the "Administrator" role. There is a general list of roles that can be edited by the server administrator. A user role contains a hierarchical set of rights.
Each user can be assigned multiple roles.
The rights contained in the main roles:
- Partner Administrator
- User
- User +
- Users -
- Technical support
- Installer
- Agrotechnology basic
- Chief agronomist
- Tracker of waybills
GLONASSSoft wiki - 2023 г
