User moderation
Last modified by Андрей Калиновский on 2023/04/25 12:59
When a new user is created, he receives the status image-20221109142941-6.png New . If the user was created through an invitation, then when he confirms the mail and creates a password, his status will take on the state image-20221109143141-7.png Confirmed .
In order to be able to moderate users, your role must have the User moderation right .
The moderation function is used by the administrator to confirm the creation of a new user. In order to use the function, you need to press the buttonimage-20221109140028-1.png User moderation in the toolbar or click on the user status.
When pressing the button image-20221109140028-1.png User moderation  window will display all available users in order from A to Z, who were registered by invitation and have statuses image-20221109143141-7.png Confirmed  or image-20221109142448-5.png Refine .
In the window that opens, you can add information about the user, check for changes in his status, and also click one of the buttons Accept , Reject  and Refine .
Reject  - the user's status will change to image-20221109141813-4.png Blocked . A user transferred to this status cannot log in, and this status is immutable, so after transferring to it, you can only delete this user.
To temporarily block, use the Enabled state change option  in the user properties. With it, you can activate and deactivate a user at any time.
Refine  - this button is activated when you uncheck one of the lines at the top of the window. Thus, you indicate that it is necessary to clarify information on filling these lines. By clicking the Refine button, the user will be transferred to the status image-20221109142448-5.png Refine . A user in this status can be re-moderated and their status can be changed.
Accept  - pressing this button will take you to the page for changing user rights:
On this page, you can change the client to which the user should belong, set the  Read Only status , and select user roles from the list of system or available client roles. After that, to save all the settings, press the button  Apply , which will also change the user status to image-20221109144332-9.png Active . This status is no longer moderated.
GLONASSSoft wiki - 2023 г
