Diagnostic report
Last modified by Андрей Калиновский on 2023/04/26 10:42
The diagnostic report is designed to quickly analyze the operation of terminals and sensors by diagnosing the activity of objects, checking the correct operation of sensors and generating the appropriate output. The user can diagnose both a specific object and the entire fleet in a complex way.
The report contains the following information:
Conclusion  - a brief result of the diagnosis.
Those. Support  - informing about detected malfunctions
The client  is the owner of the vehicle.
Object  - the name of the object.
Model  - object model.
Terminal model  - device type specified in the object card.
IMEI  - IMEI of the device.
Last entry  - date and time of the last packet received from the device.
Not connected  - the difference between the date and time of the last packet from the device and the time the report was generated.
Navigation time, hours/day  - the number of hours of navigation per day.
Navigation time  - the total duration of the time intervals in which data packets from the instruments are received with a frequency of no more than 6 minutes.
Data delay  - the ratio of the data delay time when sending from the device to the server to the total number of points with this delay. Result: The number of hours per delay entry.
Loss of data  - the ratio of the distance of the slices to the total run.
Records in motion  - the ratio of the number of records in motion to the time of motion. Result: Number of motion records per one hour of motion.
Entries at stops  - the ratio of the number of entries in stops to the time of stops. Result: Number of stop records per stop hour.
GPS/GLONASS  - average number of GPS and GLONASS satellites; navigation time without positioning. GNSS jamming - analysis of GNSS jamming situations (GNSS jamming signal comes only from UMK terminals. 9th bit of the STATUS parameter).
Result:  Proportion of records with signal suppression from the total number.
Onboard voltage  - maximum, minimum and average onboard voltage.
Battery operation  - diagnostics of the device operation from the battery.
Sensors - separate diagnostics of sensors operation with division by type:
  • Ignition
  • FLS
  • DRT
  • Fuel distribution
  • trailer temperature
  • Road mower
  • Sand spreader
  • Front and middle blade
  • Road brush
GLONASSSoft wiki - 2023 г
