Changing the subdivision of an object
Last modified by Андрей Калиновский on 2023/04/25 15:02
The "Change department" button  https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=273f68&media=sub.pngallows you to change the belonging of an object to a specific department within the client organization.
To change a unit, select an object and click the appropriate button. A dialog box will appear in which you can select the available departments from the drop-down list.
GLONASSSoft wiki - 2023 г
