Unloading combines
Last modified by Андрей Калиновский on 2023/04/25 11:31
The report is generated based on the operation of sensors such as "Combine Auger" and "Grain Level". Allows you to track how much grain and what equipment was unloaded. The equipment that accepts grain is determined by the RFID tag.
The report contains columns:
  • Event - the name of the event, the event is displayed as "Unloading [the name of the sensor by which the event is defined]".
  • Start, end - date and time of the beginning and end of the "Upload" event.
  • Duration - the duration of the event, from its beginning to its end.
  • Driver - the name of the driver associated with the RFID tag that was used during the event.
  • Object - displays the name of the object to which the driver is attached.
  • Objects nearby - if the object was not determined by RFID, then a list of objects located within a radius of 30 m from the combine during the event is displayed.
  • Object model - displays the name of the object model that was defined by the driver.
  • Hopper volume, m³. - the value entered in the object model reference "Ban volume, m³", the object for which there was an unloading event.
  • Unloading speed, l/sec. - the value entered in the reference model of the object "Speed ​​of unloading from the bunker, l/sec", the object for which there was an unloading event.
  • Given away, l. - the product of the duration of the event by the speed of unloading. Thus, the amount of given grain is calculated.
  • Given, m³. - value Given, l. converted to cubic meters.
  • Bunkers given - the amount of given grain counted in bunkers. Calculated as 1/[Bunk volume, m³]*[Given away, m³].
  • Field - the name of the geofence of the "Field" type, on which the event occurred.
  • Culture - the name of the culture on the field where the event occurred.
Also, the report built from the "Reports" tab contains totals:
  • Events - the number of events for the period.
  • Duration - the sum of the column for the period.
  • Given away, l. - the amount of the corresponding column for the period.
  • Given, m³. - the amount of the corresponding column for the period.
  • Bunkers given away - the sum of the corresponding column for the period.
GLONASSSoft wiki - 2023 г
