Working with geo objects
Last modified by Андрей Калиновский on 2023/04/26 10:24
The monitoring system allows you to track the activity of objects (machines, special equipment) on the territory of geo-objects.
To see the movement of objects in the zone of a geo object on the map, click on the name of the geo object in the tree - the map is centered on the selected geo object and a checkmark will be placed opposite its name. If the checkbox is unchecked, the geo object will be hidden. Marked geoobjects are visible only when they are in the visible part of the map.
To start tracking events and the movement of objects on the territory of a geo-object, click the "Calculation of geo-events" icon  https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=a3f56d&media=taskmain.png and select the date from the beginning of which events and trips will be taken into account. The calculation will not start immediately, but after some time, if the events took place on the selected territory before the creation of the geo object.
After that, you can build  a report on visits to a geo object  for any period from the beginning of the calculation, similar to how  a track  for objects is built.
The Reports section  hides the map window. It is designed to work with detailed reports.
GLONASSSoft wiki - 2023 г
