Multi-level sorting in interface settings
Last modified by Андрей Калиновский on 2023/04/24 17:23
Multilevel sorting allows you to sort multiple columns at the same time. This option will help you both in the process of searching for the necessary information, and for downloading reports with the logic of constructing columns you need.
To sort the list, left-click on a column heading. You will have this column sorted from lowest value to highest value:
To sort another column without canceling the first sort, hold down the Ctrl key and left-click on the heading of another column:
Thus, you have created two levels of sorting. There may be more, just keep clicking on the column headings while holding down the Ctrl key.
In order to sort the values ​​in a column from largest to smallest, you must also hold down the Ctrl key and left-click on the already sorted column:
In this way, you can sort not only report results, but also other tables in both the dashboard and the control panel.
GLONASSSoft wiki - 2023 г
