Statuses
Last modified by Андрей Калиновский on 2023/04/25 14:45
Client statuses
The "Statuses" tab in the clients section is designed to display the status of the client, as well as the history of its change.
Screenshot (555).png-   Change of status is available only to those users who belong to agents with the type "Administrative group" or
"Partner".
Statuses are located in the column with the iconScreenshot (50).pngand have the following meaning:
New.png - New;
Potential.png - Potential;
In development.png - In developing;
Test.png - Test;
On the design.png - For registration;
Injection.png - Implementation;
Works.png - Works;
Worked.png - Have worked;
Lost.png - Lost;
Rejection.png - Refusal.
In order to change the status of a client, go to the clients section.
Then select the one you need and click on its status icon. In the status change pop-up window, there is a list from which you need to select the next status.
Next, the status window opens, which contains the name of the current status, as well as a table with information about the change:
  • date of;
  • status;
  • user;
  • comment .
Screenshot (72).png - It is worth noting that filling in the comment field is mandatory.
The last step is to click on the button "Change status to ..."
The process of changing client statuses:
New - Potential;
New - Refusal;
Potential - In development;
In development - Test;
Test - For registration;
Test - Failure;
For registration - Implementation;
Implementation - Works;
Works - Worked;
Worked - Lost;
Lost - Potential;
Failure - Potential;
Object statuses
The "Statuses" tab is designed to display the status of the terminal on the object, as well as the history of status changes (sequences like "connected - put into operation - active", etc.).
Statuses are also displayed in the admin control panel. This is necessary in order to understand what is happening with the equipment and what actions need to be taken in the near future.
Statuses are:
  • Green icon - the status is checked and is permanent for the object
  • Blue icon - status needs to be checked and related work to be done
  • Yellow icon - the main time of transfer to status has expired
  • Red icon - you need to change the status URGENTLY
    Status meaning:
    New image-20220602150729-26.pngThe status is assigned to new objects, that is, when creating (loading a directory)
    Canceled image-20220602150804-27.pngThe status can be assigned to equipment on which nothing is installed, it is a sign that it is not necessary to install equipment at this stage or never
    Equipped image-20220602150846-28.pngThe status is assigned to an object when the equipment is fully installed and configured on it, the status is assigned by the installer after the installation of the equipment or by the TP employee based on the installer's report
    Verified image-20220602150928-29.pngThe status is assigned only after checking the operation of the installed equipment by the TP employee responsible for the client
    out of order image-20220602150947-30.pngThe status is assigned if the installed equipment does not work correctly due to the fault of the client, for example, the OSS displays incorrectly due to a faulty gun or software, while the OSS itself is installed correctly and correctly. That is, in fact, the transfer to this status should contain an instruction to the client to correct the causes of equipment malfunction.
    Active image-20220602151011-31.pngThe client changes the status to green and puts an assessment for commissioning, if the client does not set the status within 8 days, then only the moderator can change the status after checking. Therefore, it is desirable that the status blink.
    Not operated image-20220602151034-32.pngThe status is set if the object is not in operation.
    Diagnostics image-20220602151147-34.pngThe status is changed by an employee of the PC and TP, possibly a manager, and in case of delay Mod and Adm. The status is used to order diagnostics in case of errors in the operation of the object
    Service image-20220602151341-35.pngThe service status is used to carry out service work, that is, if it is assigned, it is necessary to carry out a service
    Dismantling image-20220602151356-36.pngThe status is assigned if at the time of the service the equipment is dismantled (not replaced), indicates that the work has not been completed
    Installation image-20220602151416-37.pngThe status changes after the return of previously removed equipment to the facility, possibly replacement
    Additional order image-20220602151113-33.pngThe back order status is used if the client wants to install an additional order. equipment for the facility
    Served image-20220602151451-38.pngThe status changes when the service work (additional equipment) is fully completed
    blocking image-20220602151506-39.pngTemporary lock status
    The status of a permanent block, it is impossible to return from it
    Status change process
    Change of statusA comment
    NewServer Moderator or Tech. support download via import all client machines
    New > CanceledServer Moderator or Tech. support moves objects that do not need to be installed at this stage to "Cancelled"
    New > DecommissionedServer Moderator or Tech. support transfers objects to "Decommissioned" in order to remove non-existing objects from the list without deleting
    New > EquippedInstallers, Tech. support or Manager after installing all the equipment changes the status to "Equipped"
    Canceled > NewServer Moderator or Tech. support changes the status to "New" if a decision is made to install the object
    Equipped > NewServer Moderator or Tech. support changes status if the check reveals a defective installation of equipment
    Equipped > TestedThose. support or Server moderator changes status after successfully checking the operation of all installed equipment
    Equipped > DefectiveThose. support or the Manager selects the status "Faulty" if it is 100% known that the incorrect operation of the installed equipment is associated with a malfunction of the object, that is, through the fault of the client
    Verified > EquippedThe server moderator changes the status to "Equipped" if a defect is detected at the time of checking the object for the client
    Checked > Active > EquippedThe user selects "Active" if he is satisfied or "Equipped" if he is not satisfied with the operation (only suitable for first commissioning)
    Verified > ActiveThe server moderator selects "Active" for the client if he is satisfied with the operation of the installed equipment
    Checked > DiagnosticsThe server moderator selects "Diagnostics" if there are complaints about the operation of the equipment and the work needs to be completed
    Checked > Active > DiagnosticsThe user selects "Active" or "Diagnostics" if they are not satisfied with the work performed (suitable for commissioned objects)
    Faulty > DiagnosticsThose. Support or Server Moderator selects "Diagnostics" after customer faults are fixed on site
    Faulty > DiagnosticsThe user selects diagnostics after the faults due to the fault of the client are corrected at the facility
    Active > Out of serviceThose. support or Server Moderator changes status if the object is not in use
    Active > Out of serviceThe user changes the status if the object is not used, if a breakdown is detected, if he wants to install additional equipment, if you need to block the object
    Active > DiagnosticsThose. support or Server moderator changes status in case of a breakdown
    Active > ReorderThose. support or Server moderator changes the status at the time of receiving an additional order from the client
    Active > LockThose. support or Server moderator changes the status if it is necessary to block the object
    Out of Service >ActiveThose. support or Server moderator changes status or status changes automatically if the machine is put into service
    Out of Service > ActiveThe user changes the status or the status changes automatically if the machine is put into operation
    Diagnostics > CheckedThose. support or Manager changes status if the problem is fixed or not detected at the time of diagnosis
    Diagnostics > ServiceThose. support or the Manager changes the status if at the time of diagnostics deviations requiring service are detected
    Service > DismantlingInstallers, Tech. support or the Manager selects the status if the equipment is removed at the time of the service (does not change)
    Service > ServicedInstallers, Tech. support or Manager selects the status if the service work is completed
    Dismantling > MountingInstallers, Tech. support or the Manager changes its status after the previously removed equipment is installed on the site.
    Mounting > ServicedInstallers, Tech. support or Manager selects the status if the service work is completed
    Reorder > ServiceThose. support or the Manager changes the status after making a decision on the installation (after payment and approvals)
    Serviced > CheckedThose. support or Manager changes status after checking the performance of service work
    Serviced > FaultyThose. support or the Manager changes the status after checking the service work and with 100% certainty that equipment failures occur due to a malfunction of the facility due to the fault of the customer
    Serviced > ServiceThose. support or the Manager selects this status if he is not satisfied with the work performed on the service
    Blocking > ActiveThose. support or Manager selects the status to activate the object
    Blocking > ActiveThe user selects the status to activate the object
    Blocking > DiagnosticsThose. support or Manager selects status if diagnostics are required after blocking
    Blocking > DiagnosticsThe user selects the status if diagnostics are required after blocking
    Blocking > DecommissionedThose. support or Manager decommissions the object, the operation cannot be undone
GLONASSSoft wiki - 2023 г
