Working with objects
Last modified by Андрей Калиновский on 2023/04/26 10:11
The monitoring system allows you to track the activity of objects online, view the history of trips and events occurring with them for a selected period, build reports and even control devices connected to the terminal using text  commands .
To see an object on the map, click on its name in the list of objects - the map will be centered on the selected object and a check mark will be placed opposite its name. If the checkbox is unchecked, the object will be hidden. Marked objects are visible only when they are in the visible part of the map.
In order not to lose sight of the object on the map, click the icon  "Follow"  the object https://docs.glonasssoft.ru/lib/exe/fetch.php?w=20&tok=0d0444&media=follow.png
With a significant distance, several objects can be combined into a group object on  the map , clicking on which will prompt you to select one of them.
Activity and events on an object can be tracked by building  a track .
The Reports section  hides the map window. It is designed to work with detailed reports.
GLONASSSoft wiki - 2023 г
