Object activity filter
Last modified by Андрей Калиновский on 2023/04/24 17:38
The activity filter allows you to quickly select objects in the visible part of the map or across the entire database based on their activity for the selected period.
The selection of objects occurs depending on the run for the selected period. In this case, the minimum required mileage can be set manually.
The activity filter allows you not to waste time studying the indicators of idle objects, which makes it a convenient tool for daily monitoring.
GLONASSSoft wiki - 2023 г
