Object activity
Last modified by Андрей Калиновский on 2023/04/25 11:40
The "Activity of objects" report shows the total time of activity of an object for a period. For a sensor with the "virtual" type, the activity time is not considered. If the sensor is part of a virtual sensor, then it is not displayed in the report.
This report is built through the corresponding section “Reports” and belongs to the “Additional” type:
After selecting the required object and period, select the “Objects Activity” report from the list and press the “Build” button.
The report table contains the following columns:
  • Object - object name;
  • Object model - name of the object model;
  • Terminal type - terminal type specified in the object properties;
  • Terminal number - IMEI of the terminal specified in the object's properties;
  • Status - status of the object in the system. Statuses are indicated such as: New/Active/Equipped/Reordered/Serviced, etc.;
  • Last activity - the date and time of the last received data.
Then there are columns with the names of the types of sensors installed at the facility. They contain the last activity dates of the specified sensor types.
Under the main table is the table of Results:
It has the ability to determine the number of objects with the statuses “Active”, “New” and “Equipped”, “Locked” and the number of objects with other statuses. The subscription fee is not charged for objects with the status “New”, “Equipped” and “Blocked” (the functionality is being finalized).
There is also an activity analysis table, where you can see how long the device has been active, with gradations in time: no activity, activity for the last 3 days, was active more than 3/7/14/30 days ago.
GLONASSSoft wiki - 2023 г
