Additional calibration tables
Last modified by Андрей Калиновский on 2023/04/26 11:12
This article will help in creating and setting up additional calibration tables, as well as help to solve the problem of the correctness of calculations when replacing the FLS.
Additional calibration tables allow you to use several calibration tables for one sensor.
Purpose of application: when replacing a fuel level sensor, the calibration changes, but if one is used - a new calibration table, then the historical - old data in the reports will be considered according to the new table, although another sensor with a different calibration was previously installed at the facility.
To solve this problem, the functionality of additional calibration tables was implemented.
In order to create an additional calibration table, go to the list of additional calibration tables in the sensor card:
All created sensor calibration tables will be displayed in the opened window. Here you can create, edit or delete calibration tables. The list contains information about the date when the table was applied, as well as the date and time when the table was edited, and the login of the user who made the changes.
Please note that for the first or only taring table, the date of application start is not indicated. In the case of one tare table, it is applied all the time, in the case of several tare tables, the first one is applied all the time until the time when the next table starts to apply. The application period for other calibration tables works similarly: from the start of the current table to the start of the next one.
To create an additional tare table in the list of tare tables, click the add button, then fill in the tare table and specify the start time for applying the table, the additional table will be applied for data from the specified period, until the date of application of the next tare table, if any.
In the list of tare tables, you can edit and delete tare tables. Note that the only or first table without an effective date cannot be deleted.
GLONASSSoft wiki - 2023 г
