Combine harvester output
Last modified by Андрей Калиновский on 2023/04/26 11:00
This report calculates the processing area of ​​visited fields by day. When calculating the worked area, the width and technological speeds of the vehicle model are taken into account. The final values ​​of the areas are calculated taking into account the intersections of the vehicle tracks. Conventional designations are used: Sobr - processing area, SVbr - processing area, taking into account technological speeds.
The system itself determines the harvesters among the client's fleet. A sign of a combine is an indication in the model settings that the model contains a built-in unit and technological speeds.
There are two report display modes: Relative to Object and Relative to Field.
Relative to the object
Relative field
The structure of the tables is the same, consists of:
  • An object;
  • Object model;
  • Width, m. - width of the built-in unit specified in the object model;
  • Processing area, ha. - a table with the calculation of the cultivated area, divided into separate columns by day. Each cell indicates the value of the cultivated area in the form Srev/SVrev;
  • Totals - the sum of the processed area, is displayed in the form of Sobr / SVbr.
GLONASSSoft wiki - 2023 г
