Correction of address information
Last modified by Андрей Калиновский on 2023/04/24 16:48
To display address information, as well as when using the speed limit functionality, a geocoding server based on OpenStreetMap Nominatim is used, which is synchronized daily with the global OpenStreetMap service. The GLONASSSoft transport monitoring platform downloads addresses (settlement, street, building number, etc.) from there, as well as information about road signs (if it is not available, restrictions on road types are taken).
In order to make edits to the OpenStreetMap database, there are several different editors. More information about them can be found on the resource  https://wiki.openstreetmap.org/wiki/RU :
Editing
Algorithm for adjusting road restrictions for fixing speeding:
1. Create a free account at  https://www.openstreetmap.org/ to become a full member of OSM.
2. Log in to  https://www.openstreetmap.org/  and click "Edit"
3. To edit a road:
- Find the required section of the road and double-click to open it for editing.
- The speed limit is indicated in the field of the same name. If necessary, you can put down dots and cut the road line to specify the speed limit for an arbitrary section of the road.
https://docs.glonasssoft.ru/lib/exe/fetch.php?media=1_%D0%BE%D1%81%D0%BC.png
4. To edit address information:
- Find the required street or building and double-click to open the object for editing.
- The name of the street is indicated in the "Name" field, and the address of the building in the "Address information" field.
https://docs.glonasssoft.ru/lib/exe/fetch.php?media=2_%D0%BE%D1%81%D0%BC.png
5. Press the "Save" button  https://docs.glonasssoft.ru/lib/exe/fetch.php?media=3_%D0%BE%D1%81%D0%BC.png.
6. Add comments to your edits.
https://docs.glonasssoft.ru/lib/exe/fetch.php?media=4_%D0%BE%D1%81%D0%BC.png
7. Click "Save".
GLONASSSoft wiki - 2023 г
