Field work log
The field work log is a summary of all recorded work of the client for the selected period. In order to open this journal, you must click on the icon which is in the menu.
By opening the field work log, you can filter the data by facility, field, or driver. A search bar is also available.
The field work log contains the following information:
• Object Name - Displays the name of the object that processed the field.
• Object model - displays the model of the object that processed the field.
• Start of work - the date when work began on the field.
• End of work - end date of work in the field.
• Field name - displays the name of the processed field.
• Crop name - displays the name of the crop assigned to the treated field at the time of the work.
• Work type name - displays the name of the completed work type.
• Driver's name - the name of the driver assigned to the vehicle at the time of the work.
• Implement model - the model of the implement of the equipment that performed the work.
• Width, m - the width of the unit, specified during the accounting of the fact.
• Mileage, km - object's mileage registered during the period of operation.
• Fuel - displays the amount of fuel actually consumed while performing the job. The value is calculated according to the data from the FLS.
• Minimum speed - the minimum speed of the object, which was determined during the execution of the work.
• Maximum speed - the maximum speed of the object, which was determined during the execution of the work.
• Engine hours - displays the number of engine hours calculated during the period of work.
• Area, ha - displays the value of the total area of the field, using units of measurement - hectares.
• Accounting, ha - displays the value of the cultivated area upon completion of work, using units of measurement - hectares.
• Violations - a description of the violation is displayed if a fact posting with a violation was registered.
• Client Name - Displays the name of the client who owns this field treatment.
Total values for fuel, mileage, area and accounting are also displayed. The field log can be displayed in print form and also exported as Excel or PDF.
