There are two ways to send commands in the GlonassSoft system:
- Arbitrary commands - the command is sent from the command line, the command is not saved and is one-time.
- Command template - a command template is created that allows you to save a command for multiple use.
To call the window for sending commands, you need to swipe one of the objects to the left in the list of objects. The Commands button opens . Clicking on it will take you to the command sending window.
In the upper part of the window there is an input field for an arbitrary command, below it is a list of created command templates.
To send an arbitrary command, enter it in the Command field and click send.
To send a command from a command template, click on one of the commands in the list.
After sending a command, it will be displayed in the History of sent commands list .
It displays a list of commands sent to the device for the day, read the response of the device and send the command again.
