Field registry
Registry of fields - a list of fields on which there were any works for the selected period, as well as visits to the fields by objects. Works can be both accounted for and unaccounted for. This section is in the dwarf menu:
The registry window contains the following subsections:
Download filter
Includes selection of the date for which the fields must be loaded and a set of restrictions when displaying the resulting list of fields.
Diagram
The Area - Crop bar graph allows you to assess the status of crop processing. The column colors are the colors assigned to the crops. The chart also displays the cultivated area (counted work) and the total crop area.
Total
Final data:
• Total number of fields and their area
• The number of fields and their area, processed without certain technologies (without work)
• Number of fields with recorded work and their area
• Number of fields with unrecorded work and their area
Field List
The list of fields is grouped by culture. The field table contains the following columns:
• Field
• Crop year
• Culture
• Type of work
• Field area
• Worked field area
• Field work status
• Fact - for a quick transition to accounting for the fact, accounting for work. • Client
Fields with unaccounted jobs are highlighted in red.
