Creating and editing fields
A field is a piece of land that is used for agricultural purposes.
Within the framework of the system, "Field" is a special case of a geo object, therefore it has all its characteristics: name, contour type, contour, area, etc. Agricultural purposes or purpose, what actually distinguishes a field from a geoobject, is determined by the year of harvest, crop rotation, annual planning, operational planning, as well as the possibility of accounting for actual work in the fields.
To create fields, go to the appropriate section and click on the icon in the fields tree:
After clicking on the icon, a section with settings for creating fields will be available, tools for managing the drawn figure on the map will appear on the map.
In the field creation settings, you can specify:
- Field name
- Subdivision
- total area
- General perimeter
- The beginning and end of the harvest year is the period of work on the field.
- Field display settings on the map: border thickness and color, fill color of the field shape, as well as the zoom level from which the field will be displayed on the map.
Also, when switching to the field creation mode, tools for editing the shape on the map will be displayed in the upper left part of the map area:
- switching to the mode of “drawing” the figure of the field, through the installation of points on the map.
- editing the points of the figure, moving already established points.
- moving an already drawn figure on the map.
- a tool for cutting out an area inside the field. This tool allows you to “cut out” an area inside the field, it is useful if there is an object on the field that interferes with the processing of the field, or there is an area in the field that does not need to be processed.
- deleting the figure drawn on the map.
Once created, the field outlines can be seen on the map. In order to receive data on the activity of machinery within these contours, it is necessary to indicate the boundaries of the crop year through the opening / closing of the crop year of the field / fields. The creation of the structure of sown areas occurs through the assignment of crops to fields. To do this, you must have a completed directory of crops and culture technologies.
Crops can be assigned manually through the Annual Planning form. Annual Planning can be created for several fields by selecting them with checkboxes and clicking on the icon on the toolbar. You can also quickly create an annual plan for an individual field by clicking on the icon in the row of the field tree. Cultures can also be assigned via import:
The system provides a template to fill out and downloads it.
After all these actions, the user of the system has a loaded list of fields, a crop is indicated for each field, a crop year is opened, and the calculation of equipment activity is started. The system "Agrotechnology" is ready for the analysis of ongoing work.
Filters
The display of fields in the tree depends on a set of filters:
1. Field visiting filter - displays fields that were visited during a specified period of time.
You can also adjust the duration of stay in the field area or limit the filter to the visible area of the map.
2. Year of the field - displays the fields of the given year
3. Culture - displays the fields of the given culture
4. Grouping fields. The following types of grouping are available:
• No grouping.
• Culture.
• Status.
• Division.
• Client.
• Status-Culture.
• Culture-Division.
• Division-Culture.
• Client-Department.
• Client-Culture.
• File.
Grouping by file name when importing fields, also displays the grouping when synchronizing fields from the last planning year.
5. Search by field name.
6. Unplanned fields.
7. Fields planned without violations.
8. Fields planned with violations.
9. Fields on which work was performed without violations.
10. Fields for which the work was completed in violation of the deadlines.
Map
The map is used to display the fields of the client. Fields to be displayed on the map are selected in the field tree. In user settings, you can also set the scale from which the fields will be displayed on the map.
When you hover over the field outlines, tooltips are displayed that contain the following information:
• Field name.
• Status of the crop year.
• Culture.
• Technology.
• Square.
• Productivity.
• Gross collection.
• Division.
• Works.
• The number of scheduled jobs accounted for and what kind of work is the current plan.
If there is a crop rotation for the previous year, the completed data for the previous year is also displayed.
A set of tools for working with the field. Duplicates the toolbar in the field tree:
There are also buttons on the map for selecting an area and creating an annual plan:
With these buttons, it is possible to assign an annual plan to the fields marked on the map.
Before planning, a page is additionally displayed where it is possible to additionally filter the selected fields grouped by crops.
The button "Annual planning" allows you to go directly to the annual planning.
If one field is selected, the annual plan card for that field will simply open. In the case of a group operation (more than one field selected), all selected fields must not have an annual plan, otherwise this will result in an error.
